File Request ms-16p7 MSI GL63 8SE
octavio
MSI GL63 8SE
Hi, i want to know if the bios file include the DMI information because i need for example the information of realtek because my laptop no detect drivers correctly. I need a bios backup
octavio
It no work because this doesn't have DMI information, I need a backup. Can you help me with this?
At the moment, my laptop work unstable using this bios, my GPU no works correctly in games. The max percent of GPU use is 1% approximatly when it should be 50% or more. My laptop doesn't show audio adapter information. Windows Update want to install drivers of a Xenon, my laptop is lose without this information and it doesn't know how work correctly
board model is ms-16p7 ?
check under all stickers and also under heat sink
octavio
The bios seems to work but i turn on the laptop and it open bios automatically, i can't run system operative.
I tried to update the bios using the bios official of my laptop but now it is frezed sometimes the bios.
What do you recommend to do?
the bios is working OK
please check all things carefully
octavio
The BIOS work spectacular (it solve the freezes randoms while run Operating System or when I am in the bios). Now, I have another problem, the GPU no work, for example, when I run a video game, the game run very slow or not work (before of all this, it worked good), I saw the task manager and the use of GPU is 0∼1 percent... Conclution: the GPU isn't work correctly, I think that the problem could be solve if I flash bios of GPU.
What do you think?
What do you think?
  • ms-16p7 new.zip
It don't work yet. The GPU give picks jumps sometimes and after that go to 0 percent
seems this problem is not related to bios
you need to check all parts of motherboard
